I have a klf400 Kawasaki bayou that has been giving me fits, it will idle fine but when i go to give it the gas it spits and sputters and wont run smooth, i have took the card apart 2 times and cleaned it, i have put new plugs in it, any ideas what might be doing this?
    • By marlon smith
    • By dkgg5755
    • Guest
      By Guest
    • By T37Mark
    • By Asand211
      I've got a 1995 220 Bayou and the electric start does not work.  When I got it the machine was pretty rough but I was told it ran less than a year ago.  The key switch had been cut off and wires  twisted after the key was lost.  I bought a new ignition switch and repaired the wiring and it is working correctly.  It is in neutral and the neutral light is on when the key is turned on but I get nothing when pressing the start button.  I verified there is no voltage going to the starter from the solenoid.  The fuse in the solenoid is good.  Something I found that is odd is that I get positive voltage(12 volts) to the brown, black, and white wires that run into the solenoid when the key is on.  That doesn't make sense to me but I could be wrong.  I would appreciate any help I can get. Thank you in advance.
