20 hours ago, morks said:
I was jumping the quad with a freshly charged car battery that has 12v while cranking.
Do you have a good battery in it, needs that to power everything to spark. So are you saying its sparking all the time and when you push the start button it doesnt spark. I would check out the CDI connections and get a manual to chase down wiring problems, a lot of differnt circuits are involved in the starting procedure.
I am jumping it from a freshly charged car battery. It doesn't spark until I let off the ignition button. Where can I find a diagram online? I have been looking for one. Was checking the ignition coil today and primary windings read okay, secondary read okay without the boot, however I get nothing with the boot...
Awesome thanks! Just got it to fire. Ripped it all up and found some chaffed wires, and I tried bypassing the key, and it worked. Weird because nothing seemed wrong with the key. It was all clean and worked as it should, and the chaffed wire wasn't too bad. But she runs! Going to clean the carb good, add a few things, should be a cheap running quad!
  • 3 months later...
What wires where they?
    • By 88bigbear
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By TomJulio
      My 1992 TRX00 recently stopped firing.  I understand this is a common problem. I have ordered an aftermarket CDI unit.    TJ
    • By marlon smith
