I have a klf400 Kawasaki bayou that has been giving me fits, it will idle fine but when i go to give it the gas it spits and sputters and wont run smooth, i have took the card apart 2 times and cleaned it, i have put new plugs in it, any ideas what might be doing this?
    • By mehim
    • By marlon smith
    • By dkgg5755
    • Guest
      By Guest
    • By T37Mark
