i have a kazuma falcon 150 it was running good for a while but lately it has been hesitating and now its not but its so slow now. i can have the throttle full but it barely moves. what could be wrong?
there is probably a clutch adjustment. you could try that. it has the revs? on mine it is on the throttle side of the bike, it looks like a slotted screw inside a nut. not sure left or right on yours to adjust more, but once tight, back off half a turn ...
Thank you for the reply. I can have it in neutral and rev it and it revs high but drivin it's slow. Do you have any pictures of it? I'll google it and see if I can't find it thanks
    • By Elk
      2002 Polaris Magnum 325
    • By quadmaniac
    • By HoldenBoy
      Hi all,
    • By 97kingquad
    • By PupATV
      Hey guys! I am new here to the forum and need some help getting my Polaris 325 Magnum 2001 Running.....So I got it for free and it has never run quite right...I put a aftermarket carb on it last year and it was running fine but it only went like 20 maybe 25mph max......But then the needle and seat sealed leaked within a yeah and it flooded it REALLY bad so I changed the oil because it was full of gas. So then I put a genuine Polaris carb on it and I have it set to all the factory specs, but it was still not running right....So I replaced the ignition coil and the spark plug and that solved one of the problems I had (It would bog down and stop running when i would go up a hill) But it still didn't have that much "Punch" to it like my Kawasaki Prairie 300 ans Suzuki Kingkuad 300.....So I replaced the CDI but it's still not running right! It's acting like it rich kinda....So it runs mostly okayish when I have the airfilter on but the top of the airbox off but as soon as I put the airbox lid on it like REALLY bogs down and wants to stall really bad. I have the carb at the factory specs and it has a pretty new fuel pump so I have no ideas whats going wrong! It still nly has a top speed of only about 30-35mph and it sounds like it's choking the whole time! Thank you for sticking to the end, and I hope you guys can help me!
      -PupATV
