  • 5 years later...
Did you purchase that manual? If so, how detailed was it? I have a 110 that has spark and compression but won't "run". We've cleaned everything and replaced the stater. I have a new harness but with the spin-over and plug firing; I'm dying as to what is really wrong. I am afraid my next step is to tear-down the top end and look 'inside.'
FYI, we did get it to catch and run yesterday; it happened by accident when the air-filter line that connects to the case popped off and it lit right up. Been tinkering with air-flow issue/carb adjustments sense. Its not fixed but it's closer.
    • By docdoug72
    • By wanrep
    • By wanrep
      YFZ05YYXH
      YF05RH
