2001 AC 300 Green
When seating the fuel mixture screw is it supposed to protrude slightly? I can see the tip sticking out. Im just wondering if what I think is seat is actually to far in. Should it be below the surface already when I begin backing out 2-2 1/4 reset?
Edited by FTPVic
    • By Louznmemind
    • By hunky
      Thanks for looking!
    • By nduray3
      Is there anyway to make the pilot screw accessible on a 1996 Suzuki king quad
    • By DaveswMN
      Thanks for any thoughts.
