On 2/15/2025 at 12:31 PM, Mech said:
Can you please tell me if this is the diagram I would use to figure out what all the wires on my Kill Switch Assembly go to? I don't have a kill switch on my 01 Bear Tracker 250 and the parts are discontinued. most of the compatible ones that I have found don't have all the same wires (mine tends to have more) and the connectors are different. I'm not experienced enough to know how to remedy this issue. I thought that i could just pull the brass terminals out and get connectors that match up and reconnect it that way, but I don't know if that will work as mine I believe has 8 wires and most of the others have 6-7. my original had a 6 pin connector with brown, yellow, bue, blue with black, green, black and a 2 pin connector with red with black and red with white.
Yes that would be the one ,it tell you which color wire goes where if you get an OEM switch, but aftermarket switches dont always come with the same color wires as OEM so you have to figure out which wire goes where by taking the switch apart ans visually inspecting.
You can test the internal workings of an aftermarket switch with a multimeter. Use the continuity buzzer to figure which wires are connected by which switch/button. Then use that knowledge to match the new switch up to the wiring diagram's switch schematic.. That's the box diagram of each switch showing what's contacted by bars when it's on or off.
If you do dismantle a switch be very careful not to loose the tiny springs or balls from inside it.
    • By OldATVowner
    • By oztrax
      MAX 4 6X6 2008
    • By HeWasRidinDirty
      The one I need to replace has a 2 wire plug coming out of it. Searching eBay I see tons of them with only 1 wire . WTH???
    • By crankin
    • By wilmpie
      hi everybody
      I have a kymco mxu 250 automatic from 2006 250 cc  that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
      if i shutdown the motor and push the quad and restart then its in neutral and don't go forwards or backwards, i already checkt if my motor is running good stationairy .
      what can it be or what can i do to fix this?
      thanx in advance
      p.s. Sorry for my bad english it's not my first language.
