This is a trick that I don't usually suggest, unless I feel the person is able to do it. It sounds like you have been into this, so here it goes.
Take the spark plug wire off of the spark plug. With the air intake to the carb taken off, cover the carb with your hand to create an almost air tight seal. engage the starter to create a high vacum inside the carb. This is basically the same as choking the carb, but a much tighter seal. Do it a few times, then connect the spark plug and start it to clear the gas.
What you are doing is drawing air and gas througth the carb. This may dislodge debree and trash in the small passages, as well as draw gass out of the air passages.
If this doesn't work, you can do it while it is running. Put you hand over the carb untill it is about to die, then release. You need to be cautious of backfire, if you do this. And only do this if you are confident you can do it.
I have cleared many carbs like this. But, until you've done it a couple times, you may question it. From my Olds 455 to my B&S edger. If it has a carb, this may work.
Also, if you do it when it is running, you may hear if you have a vacum or intake leak. I have heard them whistle like a tea kettle.
One last caution. hot hot hot, and gas burns... fast...
    • By PupATV
      Hey guys! I am new here to the forum and need some help getting my Polaris 325 Magnum 2001 Running.....So I got it for free and it has never run quite right...I put a aftermarket carb on it last year and it was running fine but it only went like 20 maybe 25mph max......But then the needle and seat sealed leaked within a yeah and it flooded it REALLY bad so I changed the oil because it was full of gas. So then I put a genuine Polaris carb on it and I have it set to all the factory specs, but it was still not running right....So I replaced the ignition coil and the spark plug and that solved one of the problems I had (It would bog down and stop running when i would go up a hill) But it still didn't have that much "Punch" to it like my Kawasaki Prairie 300 ans Suzuki Kingkuad 300.....So I replaced the CDI but it's still not running right! It's acting like it rich kinda....So it runs mostly okayish when I have the airfilter on but the top of the airbox off but as soon as I put the airbox lid on it like REALLY bogs down and wants to stall really bad. I have the carb at the factory specs and it has a pretty new fuel pump so I have no ideas whats going wrong! It still nly has a top speed of only about 30-35mph and it sounds like it's choking the whole time! Thank you for sticking to the end, and I hope you guys can help me!
      -PupATV
    • By bhristianzx12
      I have acquired a free 92 Polaris 350L 4X4. Ive replaced carburetor from ebay, replaced spark plug, im trying to pull start but sounds like it doesnt want to fire. Spark is a bright orange spark (checked with spark plug tester), replaced plug, pre mixed gas from an external gravity feed tank. Compression test good. Anyone got any recommendations for me?
    • By jhamrick75
    • By Brad1968
      I purchased a '87 Moto 225. It didn't run. After getting it running, I was surprised it smoked like a smoke stack because it was rather quick. I'm guessing it's the head gasket.
      Has anyone had a smoking problem?
    • By Bobbywolf
      I am working on a basket case for a friend.  It is a 98 Big Bear (YFM350FWB).  It came with a parts machine which is a 96, which I am coming to find out is VERY different from his machine.
      Anyway, first thing is first.  I checked compression, 150psi.  Valves are set correctly, and the engine is in time.  I cleaned the carb, and there was some junk in the passages.  It is a chinese carb, which I figured from the lack of markings or lettering altogether.
      The bike runs.  It idles ok, but breaks up badly under acceleration.  Pulling a new spark plug shows it is running lean.  White strap, with no black whatsoever.  So I have the carb adjusted with the mixture screw out way too much (about 5 turns), and the diaphragm needle lifted to the top slot.  It is still not getting enough fuel (or too much air).  It backfires through the carb, and cannot get above idle without carrying on.  The carb boot is in good shape, so it isn't pulling any air there.  I did test this as well by spraying ether around the boot when running, looking for intake leaks.
      Anything big I am missing here?  I am starting to believe that this chinese carb is the issue.  This quad came with the original carb, which I would like to rebuild and use, but the mixture screw is totally stuck, and stripped way down in its recess.
      Thanks for any assistance.
