Similar Tagged Content
By Guythis448
Looking for help on wiring up stock wiring harness specifically for a '88 Honda TRX 300
If anyone could drop a link or send me a PM it would be much appreciated
By Reece K.
I just recently bought a 1994 Yamaha Timberwolf 4x4 from a buddy who had the wheeler sitting in his garage for 7 years. I got it home and fired it up pushed it out of the garage and tried to shift it and it wouldn't shift. First it would click like it was shifting, but the wheeler wouldn't move and when I hit the gas it revved up like I was in nuetral. After trying some more it became stuck in 1st gear and wouldnt shift at all. But it later broke loose agian and acts like it is in neutral again. I took the motor off the machine to make it easier to work on.After asking friends they were convinced it was a clutch problem but after opening up the casing for the clutch I don't see anything out of the ordinary and am concerned that it may be a transmission problem. Any help would be greatly appreciated thank you.
By Guest Fox300exchic
The Hop-Up: You may be saying to yourself, “that’s a chick bike,” and you’re right. But honestly, it’s so much more than that. It’s one badass bike. http://www.quadmagazine.com/quad/features/article/0,24942,1587044,00.html
By dyyjrr9
I just got a 1991 Yamaha Moto 4 for my son and I am looking for a service repair manual. I know that the timing chain needs replaced.
By alexcross324
Hi all, I try to find this manual in the threads but you have a lot of stock here
Cannot find this particular manual.
I found it for YFM200 but not sure if they are the same.
Thanks if you could help me with that.
Im new here so if I did something wrong, please tell me.
Similar Topics
By PolarisRich
I thought I would make a quick "How-to" on setting wheel alignment since I was flipping my tie rod ends and I was going to have to re-align the wheels anyways.
Here's some of the tools you will need...
1.) Start with the ATV on a smooth and level surface, like a cement garage floor or driveway.
2.)Center up (Eyeball It) the handle bars and lock them into place with 2 ratchet straps, one on each side of handle bars. This of course prevents them from moving when your adjusting the tie-rods.
3.) Place two Jack Stands approximately 2 feet in front of the atv even with the outside edge of the two front wheels.
4.) Wrap a length of string all the way around the ATV and Jack Stands, Start and end at the rear hitch. Make sure the string is the same height from the ground on all 4 wheels. I like to attach a few elastic bands to both ends of the string before attaching the string to the hitch. This makes it easier to adjust the strings when moving the Jack Stands.
4.) Break lose the inner and outer tie-rod nuts. NOTE! Make sure you use 2 wrenches, one on the nut and one on the ball joint. Damage can occur by only using one wrench.
5.) Adjust the string by moving the Jack Stands in or out untill the string just touches both of the side surfaces of the rear tires on each side of the ATV. This will take some time to get it right but it needs to be done!
Check manufacturers wheel alignment specifications on your specific make and model before you adjust any components.
For this wheel alignment I'm using the Polaris Specs which seems to be a common setting.
Polaris - The recommended toe alignment is 1/8″ to 1/4″ toe out. This is a total amount, not per wheel.
6.) On the front rim, measure the distance from the string to the rim at the front and rear edges of the rim. The rear measurement should be 1/16″ - 1/8″ (.2 to .3 cm) more than the front measurement.
7.) If an adjustment is necessary, Turn the tie rod itself with a wrench or your hand in small increments. It doesn't take much to move the tire a long way, so go slow. Keep re-checking your measurement's until you have a 1/16″ - 1/8″ differance to the string.
6.) Once your satisfied that you have the correct "Toe Out" measurements you can tighten up the inner and outter tie-rod nuts on both sides. AGAIN...make sure to use 2 wrenches.
7.) Now take your ATV for a test drive to test your adjustments. If it still pulls one way or the other, just repeat the above steps to tweek the adjustments again utill your happy.
The whole process only takes about 15-20 min.
By michaelnewell
I took front brakes apart recently and found pistons frozen in calipers. Havent been able to find cheap calipers for this bike
By John Victor
My father-in-law gave my boy a 1999 350 Big Bear. It's been sitting in a barn for a bunch of years. It runs great! My boy has been riding a couple weeks now and it has developed a squeal coming from the front end when you get off the gas at speed. No noise during acceleration. At first I thought brakes. I took it for a ride and I don't think it is the brakes. I feel it is the front prop shaft U-joints, front differential or one/both axles. I pulled the fill plug on the differential and I can't find anywhere how much gear oil should be in there. My gut says up to the fill opening. It doesn't have a manual. It's wet in there, just don't see any gear oil.
#1 Should I fill the differential with gear oil up to the fill opening?
#2 How do I check or know if the u-joints are bad? That looks like a "Big Bear" of a job if they don't need to be replaced.
#3 What else could it be? I don't think it is the front bearings. I jacked the front wheels off ground and no play in the right wheel. Very little play in the left wheel, looks like the lower control bushing is where that play is coming from. The rubber CV boots look original but all still intact. Wheels spin easily without any noise.
Thanks for any help!
By Jeremy Morris
If you're getting that pesky leaky seal on the pinion of your front differential and the pinion has allot of play, polaris won't sell the bushing needed to repair it properly without having to shell out big bucks for the complete ring and pinion kit.
I have a kit with an upgraded bushing, Japanese made bearing and USmade seal
50 shipped in the US and 55 to Canada
By Ed Zeppeli
Hi,
Oddly I'm having a hard time ordering front brake shoes for my '98.
I'd appreciate recommendations on decent, widely available shoes if possible. Ideally available in Canada on short notice.
Thanks much,
Warren
