By Topendcol
Col
By p5200
By Spritee1
polaris 2008 50 outlaw automatic: got the 50 for free. would only run with chock on, replaced the carburator with new. I can't get the unit to an idle where the machine doesn't move forward. if I do get it to idle down within a few moments it will die. got something to try?
By 86096
I have recently acquired a 1985 Suzuki lt230ge quadrunner. It has an automatic clutch. How do you ride it. do I select a gear and then give it gas and it will go? What about downshifting? I don't want to jump on it and go and risk busting something on this old rig. Any advice would be appreciated. Thanks in advance!!!
By Indiana-George
I'm new to the mechanics of riding. I've ridden quads and love it, but I've never really owned one of my own. I bought this quad in pretty rough shape and have been slowly restoring it. I'm almost ready to kick it over, but I'm doing a little research before i add fluids. I'm wondering what kind of oil i should use. I know the specs call for 10w40, but with the age and brand of my quad I'm curious to hear an experienced opinion. And since I'm just getting started with this forum, I don't have access to the service manuals yet. Any and all advice is welcome and appreciated! Thanks and happy riding!
Similar Tagged Forum Content
- 9 replies
- 3,795 views
