Last month i got a double hernia at work. Workmans comp paid for the surgry and lost wages, im still not back to work. The pain was severe for a while, i couldnt imagine going throught it without the percs. The thing thats driving me nuts is i cant ride my Grizzly, i just want to ride so bad i may just go insain before i finish healing
    • By HoldenBoy
    • By Need-help-with-quads
    • By Topendcol
      First issue was fuel pump wont start once ignition has been turned on. Replaced the pump as I had one on hand, than noticed no power so replaced the fuel pump relay as that was were i traced the power to. Still nothing so further inspection looks like signal is coming from the PCM (FLR B20) but not switching the the brown wire to the fuel pump. Ive checked the operation of the bank angle sensor and it appears operational. Fuses and wiring all appear OK. The engine stop relay also tests OK. Ive been through the repair manual and diagrams but to no avail. Fully stumped, any tips would be helpful. Thanks
      Col
    • By p5200
      I'm assuming, it's alright to test the engine after adjusting valves without the rear axle installed? Can someone please verify this? I'm waiting on axle parts and wanting to get that done while waiting. Thanks! 🙂
