Just replaced rear bake on 2007 rancher 420es. Instead of taking cables loose i took off the brake arm (mistake) got it all back together but what is the purpose of the brake indicator
    • By Cj Winds
    • By 88classic
      I have (2) sets of brand new plastics available for Honda Rancher 420 2014-2023. These are genuine genuine OEM Honda plastics. One set is white and the other set is green. The boxes these are in are too big to ship.(Unless you want to pay for it. If so, lookup your own shipping rates from 17325 and box size is 58"x35"x18").  $400
    • By vaneleus
    • By jeffrocdx
    • By Olchap
      Thank you,
      Olchap
