I just joined the site and I am looking forward to the wealth of info. I am buying a new carb for it and after the install, will there be anything that I can do to prime it (carb) with fuel ? I assume that I would use the primer on the side of the carb ? Any suggestions for a newby. I also have a 2005 350 ES 4x4 that has been sitting for a few years . I am guessing that I will have to pull that carb and clean it also, since it wont start either. Please excuse the grammer, I am computer dumb.
Thanks in advance.
the new carb should be ok with everything hooked up to get fuel. the bowl should fill as soon as the petcock is turned on. any machine that has sat will usually need the fuel dumped and the carb cleaned. hopefully the fuel was turned off which would have minimumized varnsihing. good luck !!
    • By joezee13
    • By middlebrookgt
      Hi All.  I introduced myself some weeks ago with my 2006 LT-F400F that needed a list of repairs including replacing the cracked generator cover.  It is back together as of last night and cranks up, idles and revs high pretty well.  Needs some fine tuning and stop backfiring at stop.
      The big issue is it will not go into gear.  I reassembled the insides with help from y’all’s posts.  The transfer selector moves from H-L-R, and the foot shifter moves thru the gears and finds neutral easily enough.  Before I tear it back open, the  transfer selector on top does not move as far as the repair manual says.  The diagram shows the shaft moving something like 40 degrees between L and H and 50+ degrees between L and R but it doesn’t move that far even though it finds the indent areas and moves well.
      Could this be the problem.  I aligned all the dots on the shifter gears inside and it appeared to not be binding anywhere.  I do hear the gears touching when I shift like they are trying to engage, but zero movement from the ARV
      Are there better/bigger photos somewhere that would allow me to be confident I included all the washers and bushings, etc?  If I had any doubt on parts that were laying inside after the cover broke then I purchased replacements from online stores.
      TIA for any input or feedback!!  Pics are from when I first took the generator cover off.
    • By 95kingQuad
      As the title says I am on the search for a used OEM 1995 King Quad Carb. I believe it says Mikuni on the side. If you could even help me find info on which carb it is exactly that would be helpful too, or motorcycles/other quads that use the same carb. Thanks!
    • By Ejwill
      I rebuilt the top end on my 2007 Honda Trx500fe. It ran fine right after the rebuilt. But now when I try to crank it it blows Bach through the carburetor. I held my hand over the opening for the intake air and it blew gas back on my hand. Can figure out what happened all of a sudden. It was cranking and was able to ride it running through all the gears. Now can get it to crank just blowing gas back to the air filter. Need help again. Starting to think I should have walked away from this one.
    • By roggers
      Hi everyone,
       I often work on both ATVs and larger construction equipment, and I’m always on the hunt for solid OEM manuals—service, repair, and parts. The usual searches give a lot of random PDFs or unofficial scans that aren’t very trustworthy.
      What online sources do you all use when you need a factory manual quickly? Are there sites you’ve found that consistently provide genuine OEM content for ATVs or heavy machinery?
      I recently came across Heavy Equipment Manual, which claims to provide verified OEM service and parts manuals (covering brands like Caterpillar, Komatsu, Kubota, etc.). Has anyone here tried it, or do you have other go-to resources you’d recommend?
      I’m interested in options that are:
      ·        Fast to download
      ·        Cover both heavy equipment and ATV models
      ·        Clear on licensing and safety
      Thanks for sharing your experiences and any recommendations!
