1990 Yamaha Big Bear 350 - Throttle Cables
quintain
Hi, (Big Bear 350 4x4 1990 +- year, I am still looking for the VIN).
Quad starts and runs and has 2 cables coming out of the throttle cable assembly one goes to the carb the other is not connected.
Where should the unconnected cable be connected to ???
I have a service manual but can only find talk of "Throttle valve cable" and "Piston valve cable" I cannot see where the "piston valve cable connects.
Any help especially with pictures would be good.
Hi There,
New here but was just cleaning the carb on my 1990 Big Bear a few weekends ago. If you cant readily see exactly where that second cable goes I suspect your machine might have a newer carb on it.
On my carb, there are 2 brass "ports" for cables. One on the side for the throttle. One on the top for the piston. One actuates the butterfly, one actuated the recangle-ish piston within the carb body.
Hope this helps!
Yeah, your carb is not original but your cables are.
The second cable manually actuates the piston inside the carb body. The kind you have is actuated by vacuum.
search youtube for " yamaha big bear" and there are a couple videos on carb cleaning that shows your style carb.
I believe your carb is just a later model. Not sure if one is better that the other or not but should function just fine.
Edited by Getch
Thanks Getch
It could be that the bike is a bit newer than I thought.
I cannot see that anyone would have changed the carb for a newer one.
I have watched youtube on a number of carb cleans and when time permits I will strip it and see whats happening.
I still cannot find the VIN and I am looking in the correct area i.e. frame below or in front of gear shift, I can almost (I think) see some sort of marking on the frame behind the shift.
The bike has had a hard farming life and is banged about and surface rusted. But I hope to eventually get the VIN.
At this moment I am working, when time permits, on the brakes and have just discovered that the bleed screw on the nearside front is damaged so I need to fully strip that down.
Thank you for your interest.
check where the handlebars go into the frame too ....
Thanks o_b
I believe I downloaded your service manual which I am embarrassed to say I did not thank you for; but belatedly I do so now.
As a new user of the or indeed any quad the pic at 4.1 in the service manual did not fully make me aware of the 2nd throttle cable position.
I can see it now including the description of "Piston Valve Cable" on id #8 on the page.
I will be most interested to see what is discovered when I open up the carb. Either a bad alteration or a vacuum operated carb.
Thanks again.
Just for update
These pics of my carb may help someone else.
It is a single throttle cable that operates all that is needed BUT it has been fitted with a twin cable from the throttle assembly with one cable not connected.
The pics show the operating connection with some red tape on it.
Thanks again for help and advice.
"still trying to find my VIN looked everywhere (I think)"
  • 5 years later...
    • By HSTAR
    • By John Sinclair
    • By McG75
    • By ResQ91
      Hi Guys!
      Or ??
      Dave
