It sounded like I was shooting a gun out the exhuast when I let off the throttle & popping thru the carbs. I thought I was going to be working on the carbs all day & then sync them so they work like they should. Well I thought I would richen them up a little first to see if that would work & there it was a missing vacum cap off of the intake where you hook up a sync tool easy fix for me and then about an hour test ride. The bad part is there may have been some foul play!
I worked on the bike too! But it was a few shorter test rides for it. If it was a taller setting bike for my size & height the test ride would be longer. I love those second gear wheelies my wife can't know about them just the fix & ride part. I think today I'm going to try different air pressure in the tires and go for a test ride! lol
    • By jen
      Cannot find out why 12 vdc  4 (4) commutator starter motor has no power. It will run full speed without load. But with any load will not turn. Repaired broken brush holder and insulated an internal wire to magnet that was bare and rubbing. cleaned commutator segments. Ohm readings while slowly rotating commutator was 1 ohm.   When attempting to run  with load it will not turn and Bat vdc only pulls down to12vdc. Cannot find an internal wiring schematic.  I can buy a rebuild kit ~$35 but WTH?
    • By Asand211
    • By 97kingquad
    • By TravisCr
    • By Does_This_Look_Bent?
      Hey everyone, I just replaced the carp on my 98 Kodiak 400 with PN#4SH-14101-00-00. It starts and idles perfect, but once it’s good and warmed up, it bogs out at 3/4 throttle or more… it sounds like it’s bouncing off a rev limiter haha… I tried the air fuel screw, all the way in and out 2-1/2, and it made it a touch better… tried 2 turns and no different. Am I missing something?
