Hey guys and gals,
I aquired a 97 King Quad 300 from my dad, it has a few problems but seems to be an ok runner, so Im just trying to decide if its worth sinking a few dollars into or not.
The problems it has are an intermittent electrical problem which I have shorted out, one front axle is really screwed near the tire (shouldnt be a problem fixing that) and only one rear tire spins.
So my question is has any of you guys torn apart the rear end of these things? I had the quad lifte in the air, and the right hand side rear tire spins and there is a little resistance there (that is the one that works) but the left hand side spins really freely.
So Im not familiar with these quads and axles at all, does this just sound like a matter of throwing a new axle in the rear end? Does it sound like something more, and something in the diff let go? Rear axles easy to pull or no?
Ive checked out the diagram on cheapcycleparts, and to me it looks like there could be a lot that could go wrong inside. I plan on ripping the quad apart this winter and repairing the issues, but was hoping to get a little insight if anyone has had these rear ends apart.
Thanks.
Thanks for the reply.
Yes I have found a parts bike to get parts from. I was pondering getting a used front axle, but this guy wants 100 bucks each, and on ebay I can find them for slightly over that.
Regarding the back side not spinning though, Im not sure if its just the axle that a guy needs or what. I know the way to do it is rip it apart and look, and I will yet, just dont have time right now, so was hoping someone has had theirs apart before and tell me that yes, its basically an axle that is the only thing that can cause that symptom, or no it could be this gear etc. that will cost more then the quad is worth!
The wife and I are going to get either a couple of new can ams, king quads or maybe grizzlys in a year and a half, but was hoping to keep this one and my big bear going strong till then!
Ok lemme pick your brain then.. haha
Have you ever had to replace an axle, because the symptoms were that one day it plainly quit working? The joints all seem fine (used but fine), and one day it just quit turning. (from what my father told me)
Thats the part that has me a little... hesitant to just go and buy axles!
Thanks for the manuals, I think I downloaded them from you before and ill check again when I get home.
The quad has independent rear suspension and cv axles.
If it was a straight axle I would be a little more familiar with it, but till I rip this one apart I dont really know much!
    • By Cj Winds
    • By kevinohio
    • By sandman001
    • By kevinohio
    • By kevinohio
