Similar Tagged Content
By Kristpj
I know this tooic has been addressed by many, I’ve looked through many forums and pages. I did not find anything like the problem i have.
I have a 2007 Kingquad 450. I have a new fully charged battery. When i turn the key, the dash flashes and seems to struggle before getting fully lite. We can hear a small relay near the computer clicking, i think it is the fuel pump relay. When i turn off the engine kill switch and press the starting button relays click and all the power shuts off, i turn the key off, engine kill switch then start over, power is there. Atv will start with pull start, but not elextricly. if i try to use my winch, all power cuts and engine dies.
Can anyone tell me what it may be? or has anyone fsced an issue like this before?
By chuckufarlie
I have a 2018 Kodiak 450 EPS that just this past Sunday I ran through a bit of water.
After the puddle the belt was slipping, so I pulled over and drained the ultramatic housing and the slipping problem went away. This was all in L and everything seemed to work fine. Later when I got on a road, I put it in H, but it still rode like it was in low... i.e. I had to rev it up a lot just to get to 30mph.
When at home I pulled the ultramatic cover off to inspect, and it looked okay in there. Not much dirt, belt and everything are clean, but when I rev up the engine (with cage in place, of course), the belt doesn't get to the top of the clutch (maxes out about an inch or 1.5" from top of clutch, so maybe it is normal).. I put it back together but same thing... H seems like L still.
Do you think the clutch needs to be further dissected for cleaning, or could this be an issue with the gear selector?
By Steven Alter
I have a 2018 450 and the digital gause has started flashing on an off while driving. The backlit also goes on and off. It is worse when I hit the gas. The battery died a few weeks ago and I jumped it but its been fine until last night. Called the dealer and showed them a vid and they recommend replacing the gauge and its like 600 bucks. The machine has less than 100 hours on it. I would really hate to have to change it out. also the unit sometimes has trouble starting. Any ideas?
By Admin
View File 2014 Arctic Cat 450 ATV Service Manual
Submitter Admin Submitted 02/08/2019 Category Arctic Cat ATV
Similar Topics
By JacobSlabach
Hey I picked up a pit bike and a foreman for 800 the pit bike was running but the foreman was locked up. Sold the pit bike but when I took the top end off the piston I only found half a piston left. So knowing the rest of the piston was down in the crankcase I knew it had to be pulled and gone thru completely.
to pull the motor I went ahead and pulled the rear end off and unbolted the front diff to pull the drive shafts and pull the motor. Now I have the motor torn down completely and have all the parts of the piston removed. I know the rod and crankshaft is shot (heat discoloration and too much up and down play rod to crankshaft).
***so I’m wondering while I have the motor apart what should I check for? I know this motor died from heat as the oil in the head smelled like popcorn. So what should I check to make sure I fix the issue (overheating I assume) and not just the symptoms (blown up motor lol).
Here’s some pics
By dyyjrr9
I just got a 1991 Yamaha Moto 4 for my son and I am looking for a service repair manual. I know that the timing chain needs replaced.
By 92BayouB
Hey there all,
First off thanks for the board. My Bayou 220 has survived 3 teenagers and is on its 4th now. Up until recently it has been a virtual tank....until I decided to fix it;)
Noticed some smoking from the engine block (not exhaust) so figured it was time for a quick top end rebuild. Now that I have it all back together, it fails to start. I've pulled the starter rope until my arm is tired.
So I will be as detailed as possible and hopefully get some help.
Completed:
-New Head gasket
-New Valve seals
-New piston (standard)
-New rings (standard)
-All new seals
-Cleaned up head and valves (didn't do any resurfacing, as it all cleaned up pretty easy)
-All torqued to spec
-Piston ring gaps all checked out
-Valve clearances (Intake: .18mm, Exhaust .20mm). Not too tight, not too loose.
Pros:
-Engine IS making decent compression
-DO have spark
-Will fire for a split second if I drop some gas in the spark plug hole and pull start. Will NOT from carb and or intake valve.
Timing:
So I followed the guide of: TDC
-Flywheel aligns on the “T” mark on the engine site hole
-Cam gear mark aligned with the cover mark
Seeing as this is my first time doing a top end rebuild on an ATV. Here are my questions and concerns:
-I didn't realize (dummy me) that there are 2 TDC's. 1- Compression, 1-Exhaust.
How do I know if I'm on the right one?
-Does the cam need to be aligned a certain way when put back in? I just aligned the cam gear dimple with the cam and put it in. No alignment.
Thanks ahead of time. I feel like I'm 90% there, but I'm missing an important step for completion.
By flyinbrian365
View File 2002 Polaris Magnum 325/500 Service Manual
2002 Polaris Magnum 325/500 Full Service Manual
Submitter flyinbrian365 Submitted 05/14/2020 Category Polaris ATV
By oxidized_black
View File 2006 - 2011 Honda TRX 250EX Service Manual
5851e0ba82762_2006-2011HondaTRX250exServiceManual.pdf
Submitter oxidized_black Submitted 12/14/2016 Category Honda ATV
