Hey all just got my first ATV. Bought it for 500 dollars and real clean. Carb was stopped up so i orderd a carb kit for it and having problems. After installing everything and started it up it was revin real high after trying to figure the problem out i noticed the plunger wasnt going flush to the bottom. after trying to figure it out i realized somehow the needle does go down it seems far enough but if i remove the clip that goes inbetween the spring and needle everything works right but ive tried to install it on its side and facing up no difference.. can anyone help
Derrick
    • By Cj Winds
    • By ButchM
    • By dkgg5755
    • By Jason39
