Since I have had this Yamaha Timberwolf it has had the problem of blowing oil out the breather, Also if I am running it down a road and look back I can smell oil, So I assume its burning it as well, Plug is a light brown in color. Goes through about a quart in about 7 hours of run time, Some of which ends up in the breather box, How can I remedy this? It has good compression (Rated is 128PSI) 125PSI. And starts without problem with the electric start. I am out of ideas and the cost of oil is killing me.
Also, Heres the plug
Weird line around it?
Oil leak from where? The cam cover is tight, And oring is good (Checked it when I redid the valves)
Sorry for the bad pics, Samsung Galaxy was taking good pics until i scratched the lens -_-
And the exhaust has leaks (Around where the header meets the muffler
Ok, New problem, It seems to be running wayyy to hot, Its melting the o-rings on the valve covers and starting to melt the plastic on the oil dipstick >_> Its also now burning oil big time when its hot, I am guessing its due to the oil thinning? Or it blew the oilring out from overheating
    • By cfherrman
    • By OldATVowner
    • By flyinbrian365
      Factory service manual
    • By flyinbrian365
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
