hello to all...HI...
well im new to the quad scene and now im lovin it. i just got a 97 honda trx 300ex. when i got it,it ran ok. so ive put in a carb kit,spark plug,new rear wheels and tires adjusted the clutch but it still feels slugish..why??? i know im new to this but damn!!!
my next step is to rebuild all the gaskets on the motor as i do leak oil.and i seem to have a gass leak somewhere. can someone help me out and point me to the right direction???
also, is there anyone in the area close that knows of good ridin trails round here??
Is it all stock meaning no aftermarket pipe, air filter? You said you rebuilt the carb if you have an aftermarket pipe , performance air filter stock jetting won't work and it will not run like it should. You said it ran ok when you got it is it running worse now after the work. How did the old spark plug look & have you pulled the new plug back out and checked how it looks. A plug can tell you alot about how the motor is running. Rich or lean , burning oil etc. A compression check would help too & if the motor checks out ok I would look into the clutch if the clutch is slipping thats where your losing you get up & go. What are you comparing your quad too to say it feels sluggish it's self from how it ran when you got it or form other quads?
hey there...hi...
all is stock. i know this quad has seen better days.the slugish feeling is from what it was to now. so many carb issues. again, im new to this . dont know how and what to do to it.and now i think that starter is going.today i ran it to see how the carb kit helped. and it broke down again. the throttle body came loose. i fixed that and it drove for bout 10 minutes and it turned off again. now its getting too much gas. what a head ache...
I think I would do the compression check before sinking in money trying to fix it. If all checks out good then it may be worth getting a carb. Some carbs can be beyond rebuilding. I went thru the same thing on a Honda xr100 I ended up getting a Mikuni carb for for 38 bucks new but now I have other problems it jumped time. So it seems to have turned into a money pit. Good luck and lets know how it goes.
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By TomJulio
    • By gordonmacritchie
      all fuses are fine
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
