2012 Bombardier CAN-AM 800R XMR-5900$ ( Tampa Bay Area)
By jwh
I am new to this site. Now down to business, I have been given a Kawasaki 220, tires are trashed and it has been setting for a long time. Do I need a battery in it to find neutral? I know there is a neutral switch and if I shift down(7 times????) then up one using the neutral switch I should be in Neutral. As you see I am in a learning curve here ......coments welcome.
By P_syko
Are the cheap tires from Amazon any good? I know nothing last forever, but don’t want them to dry rot in a year.
By TimothyLindblom
Hi everyone, I’m new here and new to 4 wheelers. Just got a Yamaha bear tracker 250 and joined here to see if I could get some help.
The motor runs and it drives if it up on jackstands but if you get on and try to ride it, it starts to drive but then quits after a foot or two and dies out and won’t drive. The guy I got it from said he was running and using it shifting through all the gears great and he started it up the next day and it started this.
He told me he thought it was the U joint on the driveshaft. He said it was probably worn and needed to be replaced.
I just finished pulling the swing arm and rear end assembly to check out the U joint and there’s no play in it. It’s tight and not nearly enough play to be loose enough to not catch and go.
Any ideas on what it could actually be?
Timothy
By gwares
Price : 2500 EUR
The Ultra Bee T offers the fastest acceleration of any road-legal electric motorcycle at this price-point, with the flexibility to deal with a wide range of surfaces. With its huge capability the Ultra Bee T will appeal to people looking for a great medium distance commuter, that’s also able to turn its hand to off-road riding and green laning.
Everything works and new!
We try to capture everything in photos for you.
If you have any questions or need other photos, just ask, thanks.
Send a direct message to make an inquiry or text:
WhatsApp: +33 758 56 21 59
