If You Tow...
By Arizona
By Peisledder
Hello, can someone help me? I have a MAP error code 102-3, and the MAP has 4 wires: light blue, orange, purple, yellow. I’m getting different results on what the wires are. I don’t have wiring diagram. Can someone confirm which is ground, 5v, MAP, and Temperature?
By davefrombc
I added a pdf of the wiring of the various connectors used in vehicle socket and trailer plug wiring to the "Other ATV files" section in downloads.
By neilroy87
I have a 1990 Bayou 220 that runs pretty well for it's age--needs a new muffler, but sounds tough. Have had to start with a pull cord since I got it, and recently started troubleshooting the start button. Finding a lot of information on this issue in the forum, but haven't been able to chase it down yet. Got a new battery, new starter solenoid, and going to replace the starter relay this week, but not convinced that's going to do the trick, since I can't get the neutral light on when turning the key on. I can start it by jumping the solenoid, but the 2 black wires to the relay do not activate the starter. Bad ground or a short somewhere? Is there a good way to just test the ground?
By carkivey3
