Similar Tagged Content
By Connie Johnson Donald Hudson
Smells like gas in the oil ... Also, recently replaced belt, new BT does not have grooves on both sides, does that pose a problem? Also just bought and replaced new carburetor, never has it idled better, but give it gas and it backfires very loudly!
By LTZ-Zach
So i was riding the other day and my quad randomly shut off. It started back up and ran completely fine for a little while and then it started idling terribly.
I cleaned the carb and changed all the jets and everything except the float due to the rebuild kit not coming with one and it actually runs worse then it did before.
It will run and idle decent now but when I give it gas it dies.
Does anybody know what could be wrong?
I also changed the spark plug and air filter along with the oil and oil filter.
By chuckcnm
Hi, just picked up a MOTO 4 YFM255 and want to replace the rear brake pads. How do I get to the back. Guessing I need to remove the brake disk, question any easy way to do this?
By Mikes700efi
Can someone tell me how to remove the rear sifferential. I've got the cv axels out. Do I remove the rear shaft. Or do I pull differential off shaft. Noticed the axel shaft leaking where it go's in the engine. .
Similar Topics
By mike91
I’m just wondering what year bike i got? it seems the vin has been rubbed off i got it from a auction here in Australia engine starts but seems has a dirty carb wont idle well
and also has a problem I put it in gear and makes a grinding noise but does not move it the neutral light goes out but then when I change gear it grinds more in the higher gears as well I’m guessing the differential is stuffed so wanting to buy new part for it will start the pull down next week
this is the first bike I have worked on used to dealing with cars
By davefrombc
Very glad to see the end of 2020. Have a very Happy, safe and prosperous 2021 everyone.
By ScrappyD
Hi All,
New here and have a quad project (in the title) that needs alot of work! So I'll be bugging you guys from time to time with some Q's
It's even got a cracked frame (in a couple of places), never been washed in it's life and is a bit of wreck but the girlfriend likes it so thats my life for the nexct however long lol
Cheers
ScrappyD
By JonBat68
I have a 99 250 Quadrunner. Currently has no spark. It would run for 5 minutes, then shut off. After it cooled down about 20-30 minutes, it would start again. I ordered a new stator and found the old one was damaged (copper windings broken) I installed the new stator, filled with oil and now it has no spark. Any assistance would be helpful
By dyyjrr9
I just got a 1991 Yamaha Moto 4 for my son and I am looking for a service repair manual. I know that the timing chain needs replaced.
