(This Ad is from QUADCRAZY Classifeds, click "More" to find out how to contact the person who placed this ad.)
Selling a 2007 TRX 450R quad, has approx 20hrs on it, was built to run PRO-AM circuit. Dasha engine, exhause, fox shocks, holtz A-arms and swing arm, Many others. Have reciept for every aftermarket part. Over 12k invested in aftermarket.
More...
      QUADCRAZY NEEDS YOU!
    • By crankin
    • By digrig
      Hey everyone,
    • By Zrach
      I wanted to share a successful workaround for a "no-spark" issue on a 2009 LT-A400.
      This is specifically for cases where the CDI has been diagnosed as faulty, but the age or condition of the machine makes the cost of a brand-new OEM unit hard to justify.
      Note: This modification compromises the factory “no-start” circuits.
      On some malfunctioning CDI units the internally damaged circuitry is only partial.
      Feeding full time power to the Parking Brake pin, the unit is triggered to bypass the internal fault and produce a healthy consistent output to the Ignition coil.
      The Modification
      See the second diagram attached below for the wiring specifics.
      The Result:
      The machine has clocked over 1,000km since this repair and is still running strong with no ignition dropouts.
      ⚠️ IMPORTANT SAFETY WARNING ⚠️
      Please be aware that this modification compromises the factory safety "no-start" circuits.
      The machine will now start in gear. The safety interlock involving the handbrake is no longer functional. The machine can move unexpectedly if the starter is pressed while in gear. Proceed at your own risk. If you sell the machine or let others ride it, ensure they are fully aware that these factory safety buffers have been removed.
      Faulty CDI Workaround.pdf
    • By Ironworker709
      I have Grizzly 700 that has been pretty much totaled out in a bad accident, but it will still run and drive good...
      Will this engine swap into any of the Yamaha UTV's like thr rhino and Viking 700's?
      Was just going to sell it as is for a engine for someone who needs one pretty cheap..but been thinking about getting a UTV for the family and maybe find one with a blown engine cheap and swap it out
      I already an excellent shape 2001 Big Bear 400 4x4 for us..but kinda been looking for a good used UTV for us and the grandkids on our property to play with
      Not sure of the year..i can't remember what year it was when i picked it up for a buddy a few years ago..he went to jail after he totaled this thing and told me to pick up a few things at his house he was renting and just keep them for myself since he owed me a bunch of money before the landlord sent them to the dump...
      The first picture is when i went and picked it up for him..second is how it is now..frame is all twisted up and plastics are fubarred..going to sell the rims and tires.they stick out way too wide on my Big Bear
