If you look at my previous posts, you'll see I'm completely new to riding. I don't know much of anything about riding or mechanical issues. I picked up a 2008 Kawasaki KFX 450R and just happened to notice a wire dangling about a week ago. There's no telling how long it's been this way. I noticed it just before I took it out to the motocross track and gambled on the fact the it wasn't important enough to matter. The quad ran fine but I have to figure out what this is for before I take it out again this weekend. I questioned a few friends before coming here and none of them could tell me, definitively, what it is. Below is a link to a short video, showing the wire. Any help would be greatly appreciated. Thanks, in advance.
Wire - YouTube
I'm not sure what a chaincase cover is, but I assume that would be near the chain. This is nowhere near the chain. It's under the seat, towards the back of the engine. I don't mean any offense, but did you watch the video? It's pretty clear about the location of the wire.
On a side note, I initially thought it looked like something that might run the brake light. No dice. The brake light still works fine. With the brakes applied and as running lights with the headlights on.
I just dug in a little further and found where it fits. I took off the seat, dug around with a flashlight, and discovered a spot where that plastic piece slides in, with a place for a bolt to hold it in. I'm not sure how all of these things are falling off my bike (this is the 2nd thing to fall off in just a month) but I'm also not sure what purpose this wire serves. The end that goes in the hole is plastic, yet has wires coming out of it. Unless it's some sort of NFC chip (like smart keys), I don't see what purpose plastic could serve.
You may as well have said "controversial blue banana speaker". No clue what that is. I'm sorry, man. I know you're trying to help and I appreciate it. I looked at your pic, though, and it looks nothing like the piece I'm talking about. As I said, though, I found where it needs to go, I just have to find a way to secure it back in its spot. However, even then, I have no clue what it actually does. You have the air filter casing. You have the big plastic tube that comes off of the air filter casing. Then you have this bundle of wires with a plastic cone on the end which does.... something, apparently. I'd really like to know what it does and how important it is that it's hooked up. Like I said, I have no clue how long I've been without it. Hell, this thing could've been unplugged since I bought the bike 2 months ago. I have no idea.
If it plugs in to the tube in front of the airbox, it is an oxygen sensor. I would think if it was a sensor it wouldn't be running right, you know like spiting and spudding. If you trace the wire back where does it go?
    • By quadnut20
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By HeWasRidinDirty
      I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
    • By marlon smith
    • By jeffrocdx
