(This Ad is from QUADCRAZY Classifeds, click "More" to find out how to contact the person who placed this ad.)
PRICE REDUCED!!!! 2008 ARCTIC CAT 500 4X4 For Sale! Comes with 28" mudzilla tires on SS ITP rims and stock tires. Has jet kit and HMF pipe with 12" ground clearance without lift! Also has extra front bumper. New factory motor put in 2 years ago ...
More...
    • By tepin
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
      QUADCRAZY NEEDS YOU!
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
