im new here and have a problem bought a 04 honda 400 at and i change the centrfugal clutch,drum and one way bearing now when the engine is cold it grinds,boggs down until the motor warms up then everything works fine. put 20/50 gn4 honda oil in it also appreciate any help thanks
Welcome to QC !!! Get ahold of OX and down load a manual for it ! Might help ! What oil does honda say to put in it ?
im new here wounder if someone could help i have a 04 honda rancher 400 at and i changed my circlutch and drum and bearing now when the motor is cold it grinds,boggs down after the engine warms up everything works fine i did put 20/50 honda gn4 oil. any suggestions
    • By TomJulio
    • By gordonmacritchie
      all fuses are fine
    • By toe420
    • By digrig
      Hey everyone,
