Similar Tagged Content
By JPRICE1981
Hello everyone !! Looking for some help !! Im wanting to check my stator and pick up coil with a ohm meter and cant seem to find a guide that tells me what to read and what my reading should be !! Any help would be great !! THANKS IN ADVANCE !!
By oldcomet
Morning Folks
Ok so I have taken the front hubs apart everything is good and working fluids changed and full In 2 wheel drive the bike works great However in 4 wheel drive high I get a grinding clunking noise right near the foot pegs The universals are all brand new in the complete bike The problem just started after my last ride Sometimes I have to change the rpm to get the bike to go into gear in forward and reverse The bike doesn't make the grinding noise when I have the bike in 4 wheel driver low gear only in high gear Could the shifter need adjusting any help would be great Thanks for your time
Oldcomet
By bodatiouskid
Just bought a 2003 Kodiak 450.At take off,the belt doesnt grab for a few seconds.Is there any wat to tighten belt?& how tight should it be?
By Tivy
My boot on the drive shaft came off this weekend. When I tried to put it back on it appeared to be about 2" too large. Any explanations????
Also when the boot cam off, there was oil in the boot. Is this normal???
Thanks for your help.
By toonces
New to ATVing here and just got a '11 Grizz with the belt drive transmission and I've been suggested to take along an extra CVT belt along in remote rides just in case. I'm somewhat knowledgeable about where to get quality parts for cars but not so much for ATVs. Who makes the best CVT belt for my bike? Also, who makes just ok belts and who should I stay away from?
Also, I'm looking at getting a snatch block for a synthetic rope winch and wondered if the type rope determines what type of block you should get...or are all snatch blocks the same and I'm just thinking about this one too much?
Similar Topics
By Roy Anderson
I have had a 2002 Suzuki King Quad 500 for almost a year. This is a question I’ve posted before, but likely missed the answer due to being new to the site. Here’s the issue. When in 4 wheel drive, especially in low range, especially when pulling a load downhill, I hear a lot of clanking in the front end. As if the front drive shaft was binding then unbinding. A friend who had a 1987 Dodge 4x4, told me all the noise his front end made when in 4 wheel drive was entirely normal. So, is this something I should worry about? I have all the bodywork and tank off right now doing a valve adjustment and carb rebuild. If I gotta do something, I’d like to do it now. Lastly, I’d love to find a carb tuning guide for this era of Mikuni. Haven’t tracked one down yet. Any thoughts of where to find one? Great forum. Have really enjoyed it so far.
By MarkinAR
And the new 300FW is already wounded. Something got in a bind and blew the whole chunk of case out around the primary drive gear at the back of the motor. In the pic you can see the crack along the top...there is a big chunk missing from the bottom. And it won't roll....but the front and rear diffs both seem fine. Unfortunate. This looks to be a bit of a project. Still feels like it will shift through gears so i'm wondering if the ring and pinion just jumped a bit and blew something to pieces. I have a parts bike. But will this require the case to be split and transmission completely disassembled? I assume you can't just slide the broken primary drive out and slide the replacement in?
By StolenATV
went to sell this guy my bike and on his test drive he just took off and never came back.
The post 2015 Yamaha YFZ450R Stolen During Test Drive appeared first on STOLEN 911.
View the full article
By seth baronie
Need a stock drive clutch for a 2015 sportsman XP 1000. Part number 1322953
[email protected]
paypal ready
