Hi guys my bayou just stopped going the other day,I put a new plug in but still did not go,then all a sudden it went so I used it for about 30 minutes and it ran perfect.Now it will not start again,I have been trying for the last 2 days.I have checked all the electrics,it has plenty of spark,plenty of fuel,the valve clearances are good.It turns over fine just will not fire.Tomorrow i am goint to check the set up timing(i think thats what is called)If thats not it there is only compression left as I don,t have a tester I put my finger over the plug hole and it popped my finger so there is copmresion there maybe not enough though.
steve.
Yea plenty of fuel, I got a mate to have a look and he said there is not enough spark and what spark there is is irratic so monday I will go out and get a coil and hopefully that will fix it.
Thanks oxi but i think i found the real problem the spark plug hole thread is stripped, and as i have working on this i have found a lot of bolts that have been stripped so i think its time to scrap this lemon and spend a bit of money and get a good one.
Yes you are right but this bike has been nothing but trouble for me since i got it just 6 months ago and it has tested me to much,my own fault for not checking it out properly before buying.:-)
well I have decided to get a heli coil and see if I can get this bi*** going,this maybe a silly question but besides the mounting and as long as they have 2 pins are all coils the same for quad bikes?
    • By realpilot
    • By OldATVowner
    • By oztrax
      MAX 4 6X6 2008
