By LMI
By rjsummer
By TomJulio
My 1992 TRX00 recently stopped firing. I understand this is a common problem. I have ordered an aftermarket CDI unit. TJ
By Arizona
By Peisledder
Hello, can someone help me? I have a MAP error code 102-3, and the MAP has 4 wires: light blue, orange, purple, yellow. I’m getting different results on what the wires are. I don’t have wiring diagram. Can someone confirm which is ground, 5v, MAP, and Temperature?
