Hi everyone I have a 2001 raptor 660 and I had it up to 75 mph and everyone says there is this speed limiter that won't let it go over 75 mph. I was wondering what you could do to make it go over 75 without different gearing or sprockets. Could you remove this limiter somehow. Thank You everything is stock besides the K and N airfilter
    • By Gtc4d
      Thanks.
      Todd
    • By BillR94
    • By HHurks
      Hi to all
