Similar Tagged Content
By YamahaBB350
I have a Yamaha Big Bear 350 and the reverse doesn’t work, it shifts from low to high easily but it won’t go back to reverse. I’m new to this stuff, so I’ll take any help. Any ideas?
By Christopher Williams
Hello all,
i just rebuilt the top end of a 99 Bear Tracker 250 and it can’t get it to hit off of gasoline or starter fluid. Occasionally it will backfire. Right now I’m just trying to get it to fire off without the carburetor like I’ve done a thousand times before with other engines. Usually there is no response, but occasionally I get a backfire through the intake. ISeems like it’s out of time, but I don’t see how that could be possible.
Here’s what I know:
1. compression 120psi
2. all timing marks are lined up after numerous revolutions.
3. Strong spark.
4. Valves adjusted correctly.
Thanks in advance.
Similar Topics
By NathanFisk
I have an 2003 Kodiak 400 Automatic and for some reason the starter not engaging I’ve replaced it still nothing it spins freely but not engaging. It was running fine the day before I am no expert so can someone please help me
By AKMichael
Hello All,
I have a 1999 Yamaha Big Bear 350 4x4 trying to get fixed up so my grandson can go out in the woods with me.
We have owned it over 10 years. It got harder to start, until it finally would not. Replaced the carb. Right afterwards, it started and ran nicely, but after turning it off, would not restart. Tonight I used starting fluid and ran, then died. Adjusted the idle up a little, used more starting fluid and ran great. It idled about 15 minutes. Turned it off, and restarted. Ran it around the yard about 5 minutes. Turned it off, and would not restart.
Any ideas or suggestions would be greatly appreciated!
Thank you.
By mike91
I’m just wondering what year bike i got? it seems the vin has been rubbed off i got it from a auction here in Australia engine starts but seems has a dirty carb wont idle well
and also has a problem I put it in gear and makes a grinding noise but does not move it the neutral light goes out but then when I change gear it grinds more in the higher gears as well I’m guessing the differential is stuffed so wanting to buy new part for it will start the pull down next week
this is the first bike I have worked on used to dealing with cars
By hutchir3
Hello Folks....new to the forum. I have two Warriors (87 and 92), and an 89 Big Bear. Looking for some help with engine issues on the warrior, and my 89 Big bear backfired and died. Got spark, got gas, seems to have compression, (but haven't tested it yet...next). She rolls over good, maybe too good...seems soft. Have spark and enough compression to blow gas mist out the plug hole when cranking. Suggestions, Been running great since we got it.
By Randel1
I'm having a problem getting a CDI unit that works. The parts list calls for a 4XE-85540-00-00 CDI unit. The one currently on the ATV works but there seems to be a problem with the spark advance curve. It will idle fine an rev. to about 1.5K then starts bogging down sputtering, popping and basically running poorly. If you can get it above 2200 RPM it runs better. I have ordered and returned about 5 replacement modules that will not work at all. The unit currently on the bike has no part numbers or identification other than a Mitisibuchi logo. I am wondering if anyone else has experienced similar problems with replacement CDI's and if so what is the fix? So far I have not found a replacement CDI that will supply an pulse to the Ignition coil.
