Problem Found.
Turns out the wiring harness under the seat which goes from the left to the right side of the bike was routed under the air cleaner box instead of over which caused the harness to rub against the heat shield of the exhaust pipe causing a short to ground. Repaired wiring and rerouted harness. Problem solved.:biggrin:
