98 timberwolf cant swim
By Tim Keiper
By Panupong Pradchaphet
I have a Sportsman 450 HO and almost killed my self when loading it on my truck with ramps. It rolled off the top of the ramps and tailgate and nearly landed on me. I now want to winch the ATV in to the truck. My question is are the front side bed tiedowns in my 2011 RAM strong enough to winch to without distorting the hooks or sides of the bed?
By Mhatayas
By jwh
I am new to this site. Now down to business, I have been given a Kawasaki 220, tires are trashed and it has been setting for a long time. Do I need a battery in it to find neutral? I know there is a neutral switch and if I shift down(7 times????) then up one using the neutral switch I should be in Neutral. As you see I am in a learning curve here ......coments welcome.
By Gwbarm
IMG_4910.mov There is some slack in there but most is taken up by the gear cover,if anyone with history with these machines has had the same problem, let me know your findings. Where i am now im looking for finding replacement honda gears on Ebay and try those. I suspect the original was replaced with aftermarket gears years ago and they just worse quality as the years go by.
