When I bought my daughters 06 Foreman the winch cables were not connected to the battery. I connected the cables and everything seemed good we didn't use the winch but she went to start the quad and it just clicked did the same for me. I disconnected the + winch cable from the battery and it turned right over and did so for the rest of the day. I did hook my battery tender up over night after we got done riding. The winch is a 2000lb. super winch I have no manual on the winch. My ? is will a winch drain the battery when its not being used. I wouldn't think it would But I don't know whats going on. Since the winch cables were not connected to the battery when we got it I think there is something with the winch drawing power somehow and that's why it wasn't connected.
Update I printed off the installation page from superwinch and its wired right. It has a circuit breaker in between the battery and solenoid on the +side, ground from solenoid to - battery and then hot & neg to winch, 2 wires from solenoid too rocker switch & rocker switch has hot too ignition switch. Ive not tried the winch to see if it works I need to do that as well.
Electrical gremlins are a nightmare to trace. I would check continuity at the switch and see if it maybe bad. The winch itself may have a bad motor. It may work fine but it also maybe drawing amps away from the solenoid causing the starter to malfunction. I'm leaning towards the switch myself but that's me.
Im going to check it out today. One thing I read on the superwinch installation is the hot wire coming from the toggle switch needs to be hooked to a power source that's only hot when the key on. I don't know if the winch has ever been used it looks new and the snatch block the the superwinch strap for the hook were all in the packages unopened & in the storage compartment on the quad.
    • By docdoug72
    • By Thekevinjb
      thanks
