      QUADCRAZY NEEDS YOU!
    • By 97kingquad
    • By davefrombc
      It would be  helpful at times to have a button  where we could cont the Admin. to  make some changes to  our posts.
    • By mga
      So, i go to change the oil in my 2k Y 400 BB and, without reading what types of oil to use, i just put in 10w-40 motor oil.....then i decided to read exactly what type of oil i should be using. Apparently, the ATV oil is designed to also work with the clutch..lol...which is probably  why i was having a few issues going into the gears, or, maybe losing 1st gear going down a hill. Ok, now that i got educated i bought like 6 quarts of the "special" oil required.
      Now, my second issue is it was hard to start for some reason. Usually it fires right up. So, once started i brought it up to the garage and removed the seat, thinking maybe the battery was weak from sitting. Nope...12.5 volts, but.....a mouse decided to build his nest right on top of the battery. I cleaned that all out, but, when i went to start it, the solenoid clicks and the starter just spins. UGH. One thing after another. No wires were chewed thankfully. Just kind weird the starter would do that all of a sudden when i messed with the oil.
      Do i need to pull the starter now and check the bendix thing? It spens real nice, it just won't engage. The wrong oil wouldn't do that...would it?
    • By TravisCr
      I don't know if I shouldn't have posted but I this is my second post on this (other was in regionals Forum)  The family has a 2-up 2004 Artic Cat and a 2003 Polaris Sportman and we are looking for fun/easy rides in the Colville, WA area- 70 Miles North of Spokane WA, we have a small trailer we can haul these with but need to find some good areas for beginner.
      Thanks in advance for any suggestions.
