Ok so I changed the oil in my KLF185. I waited until it was cold to do it too. I drained the oil , cleaned the filter and then poured the new oil in until the oil was 1/2 way between the marks. I gave it about 5 pulls and the oil level went down so I put a little more in.
Then I would ride awhile and the window would show full (too much over the max) So I waited until it was cold again and then let out enough oil to get 1/2 way. Today I was riding and it frickin show full (window) and then low sometimes... What gives?
I have learned from years of dirt bikes that I always check the oil (on machines using a site glass) to check them cold and level. If you start the engine you need to let is set quit a while before looking at that site glass, it takes some time before the oil settles, making for readings all over the map. I would say it need to set at least 1/2, an hour would be even better.
BradCad
Yeah It finally started to read correct. It was a little warm when I changed it initially, so that probably was the reason I put too much. I also pulled the starter (not sure if that was even needed). But I let some out and let it sit over night and it seems to be good!
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
    • By kevinohio
    • By harryjr
    • By Rick Shropshire
    • By Need-help-with-quads
