Just bought my 1st atv is a 01 polaris trailblazer 250. I'm looking to upgrade some parts but not sure which ones to do first. I believe it's bone stock, upgrades not needed but I wanna make it look and perform better. Thanks in advance
:biggrin:I have an 01 Trailblazer. I have been beating the hell out of it for 8yrs and didn't mod anything on it.:wink: I looked into modifying mine a couple of times and in my opinion if you want a faster quad, I would buy a different one.:huh: The mods are expensive and I don't think the bang is worth the buck.:no:
Check out my pic and videos and you can see they are very tough and a lot of fun. If you are into trail riding and not worried about blowing the leaves off of the trees when you go by, the TB is awesome.
    • By wheeliewayne
      my  2012 big bear 400 is hard shifting  can anyone help me
    • By marcosphoto
    • By bigd764
    • By qcm413
      Hi,
      Thanks for a newbie on this site !
      i have grinding noise in my front differential. the front right wheel is turning and the left is try to turn but no movement and make sound like a gear broken. somebody have any idea ? not enough oil in diff ?
      thank
