Here is what appears to be an accurate photo of the inner joint from an axle on ebay.  I see no reason why it wouldn't come out, inside they are the same as any other for the most part.  Notice this ring around the outside, this is actually the where the seal contacts, not inside as is usual.
I dont see anything to keep it from coming out either, unless the inner ring has become dislodged or broken it should only create minimal resistance. I would try to get some oil or penetrating oil on the shaft once you get it out as far as you can and work it back and forth and see if it lets loose.
Hi. That 9mm play must be happening somewhere other than the circlip in it's groove, the side gears in the diff perhaps.
My guess (educated guess. fifty years mechanicing), is that it needs jiggling etc and pulling firmly by hand, then a second person ( or be very dexterous ), to give that tiny tapered edge on the cv a sharp bump.. Sort of jamb a small bar in there, lever and push slightly, then give the bar a lever by bumping it with the palm of your hand..
You'd know how they are.. you can get it on the first try or the fiftieth..  Sure doesn't seem to be anything about the design of that cv. I have heard of people breaking the whole side out of front diffs before though.. Don't ask me how.. but they did.. So be gentle.. Sharp bump with the palm..
Suppose you know what a bearing splitter is..  Used in pressing.. Two halves that bolt together and wedge bearings along shafts.. One of those would hold it and you could improvise a slide hammer..
Here's a suggestion for pulling a stuck axle out of a diff.  I use a regular 6' tiedown that I wrap one end around the axle & the other is wrapped around a large hammer/sledge hammer handle, just below the head.
With everything lined up right, you can swing the hammer which yanks the axle with more force than just pulling by hand. Give it a try, what's the worse that can happen - right?!
All points on which I would tend to agree with, and with my 37+ years as a tech you would think.  The clip is definitely in it's land when I pop the shaft out of it's spot, but I cannot account for the almost 1cm of travel before it gets stuck again.  Between there it is loose as butter - and clicks back into and out of locked position with normal force of any shaft I've ever installed.  I may try the cable tie thing, but I still think something is amiss, after that short amount of travel it seems to hit a definite firm hard spot.
I very rarely have one this difficult to remove so you may be right that something is wrong. Spocks idea is a very good one never thought to do that, when i have one this difficult i usually use a slide hammer to bump it loose, i have even had to make larger slide hammers with heavier weight to get it out, but that is rare.
Yeah the movement is strange.. The parts diagrams and manuals all say the spider and side gears in the diff aren't serviceable..  What's the bet the bike has worn the side gear thrust washers/faces..
      new to the forum saying Hello from arizonA
      im new to the forum where are good places to ride in az??
    • By KdlH
      Hello.
      I'm new to the forum, I live in the UK. I have just bought a 1995 Yamaha Moto 4 350.
      Generally the condition isn't too bad (I paid very little for it!), it looks quite original and all the plastics are quite good. The bad bits are no brakes, the rear axle bearings are shot and the transmission won't shift through the gears properly.
      I'm not planning on a full rebuild but I would like to sort it out a bit. The transmission is my main concern. If anyone has any ideas on what might be the cause I would be grateful. I can explain what's happening in more detail if required.
      Thanks everyone,
      Kester
    • By robert63
      my cat only has 100miles on it and is in mint cond. since i bought it new in 2009 it has had what i believe to b a carb problem. going down a steep hill makes it want to stall. as soon as u r on level ground its fine.and at top speed it kinda acts like its starving for gas. u let off the throtel a bit n its fine. idels good starts good. hav taken it back to dealer several times. they eithor said it didnt do it or mayb bad gas. my friend says it sounds like the float level isnt rite. any advise would realy help.
      The AMA U.S. ATV Motocross Team of Bryce Ford, Joel Hetrick and Brandon Hoag dominated in the Czech Republic at the 2024 Federation Internationale de Motocyclisme (FIM) Quadcross of Nations. It marks the sixth time that the team has secured a global championship since 2017.View the full article
