2013 Honda Fourtrax Foreman Rubicon TRX500 ( St Louis)
(This Ad is from QUADCRAZY Classifeds, click "More" to find out how to contact the person who placed this ad.)
2013 Honda Fourtrax Foreman Rubicon TRX500Model:FOURTRAX FOREMAN RUBICONMileage: 0Primary Color: GreenCondition: NewVIN: 1HFTE2606D4301426Warranty: YESThe Honda FourTrax Foreman Rubicon is a strong and practical ATV developed to tackle a...
More...
      QUADCRAZY NEEDS YOU!
    • By 2wdrancher
      Hello everyone I have done a ton of research on doing this conversion because I hate getting stuck in the stupidest places and not being able to back out. I will be documenting my conversion here and on a couple other forums and probably post a couple videos on YouTube. So what I’ve come up with is all you need is a front axles, front propeller shaft, the final shaft inside the engine and the 4x4 front engine cover . I will list all the part numbers for everything that you need and prices from about six months ago (sorry) , you DONT need to switch out hubs, knuckles, or anything like that, and if you want differential lock lock like the foreman and Rubicon you can get a foreman Rubicon front differential and propeller shaft with the diff-lock and get a knight sure four manual actuator for it and voilà you have four-wheel-drive rancher. Input from you guys is greatly appreciated thank you for your time!
      Note: I would definitely get the aftermarket HD axles because they are definitely stronger and are around the same price as oem
      FINAL SHAFT
      23611-HR3-A40  =$80.48
      BEARING
      91006-HP5-601   =$11.11
      OIL SEAL
      91202-HR0-F01   =$ 7.94
      COVER ASSY., FR. CRANKCASE
      11300-HR3-WB0   =$206.99
      PROPELLER SH AFT
      40400-HR3-A20   =$91.50
      FINAL GEAR
      41400-HR3-W50   =$714.88
      FINAL CASE BRA CKET
      50350-HR3-A20  =$7.40
      FLANGE BOLT
      95701-08016-08  =$1.49
      R. SHAFT SET
      44250-HR3-WB1  =$240.64
      L. DRIVESHAFT
      44350-HR3-WB1  =$240.64
      This is all for the 2x4 - 4x4  lever that comes in stock on the ranchers. I would definitely recommend looking for parts for wheelers on marketplace,  or craigslist
      001
      NUT, ADJUSTING
      41560-HP5-600
      $6.51
      002
      CABLE, FR. FINAL CLUTCH
      41570-HR3-A21
      $6.56
      003
      SPRING, CLUTCH CABLE
      41571-HP5-600
      $1.95
      004
      CLIP, CLUTCH CABLE
      41573-HP5-600
      $3.23
      005
      GROMMET, CLUTCH CABLE
      41716-HP5-600
      $3.12
      006
      LEVER, FR. FINAL CLUTCH
      54030-HP5-600
      $8.91
      007
      PILLOW BALL, FR. FINAL CLUTCH
      54031-HP5-601
      $10.87
      008
      BRACKET, FR. FINAL CLUTCH
      54040-HP5-601
      $11.19
      009
      SPRING, FR. FINAL CLUTCH
      54041-HP5-600
      $1.86
      010
      GATE, FR. FINAL CLUTCH
      54050-HR3-A20
      $4.55
      011
      GRIP, FR. FINAL CLUTCH
      54321-HP5-600
      $8.95
      X2 012
      BOLT, FLANGE (6MM)
      90111-162-000
      $2.54
      013
      NUT, SELF-LOCK (6MM)
      90343-ZE6-000
      $1.70
      014
      JOINT B, BRAKE ARM
      95015-32001
      $0.82
      X3 015
      BOLT, FLANGE (6X12)
      95701-06012-00
      $1.34
      Or Forman 520 w diff lock
      FINAL GEAR
      41400-HR4-A21  =$732.49
      PROPELLER SHAFT
      40400-HR4-A20  = $92.54
      And you definitely need the sure four locker for this
    • By Uglyside38
      Anyone have experience using Meier aftermarket plastics? OEM ones are shot on my quad I'm restoring and I have them "Frankenstein'd" for now...🤦🏼‍♂️😬
      Just curious on opinions on Meier as that seems to be the only place I can find any type of replacements. (And they're pretty pricey!)
    • By prdicon
      Which wheel bearings brand is best?
      Also, I know 2 seals come with each bearings. But there is also a small seal, what is it for?
