I have a 05 king quad 700, cranks and runs fine but when put it in reverse it spits and sputters and barley moves. Also taking off in high or low its sluggish for a second then takes off. It also has over sized super swampers on them. Never owned a automatic so I don't know anything bout clutches in the motor. Great full for any help!!
    • By OldATVowner
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By sandman001
      any ideas how to correct
    • By hunky
      Thanks for looking!
