By JakeWens
I’m pretty sure it’s an 01, that’s what it looks like based on some of the parts I’ve gotten for it already. I’ve been chasing a no spark since I got it, I bypassed the kill switch, I replaced the CDI, the voltage regulator, and the ignition coil. The battery is new, the headlights work so I know there is power leaving the battery. I’m not sure what else to do or check, I’m a heavy equipment mechanic but little a guy gf like this throws me for a loop, any help is definitely appreciated
By Hunterthefighter
My yamaha timberwolf 250 4x4 (unsure the exact year) wity the clutch less manual transmission will shift into the diffrent gears but will not engage 1-5, but will engage reverse. So it knows its in first but won't move forward. Reverse is immediate and will move. 1-5 act like neutral. Is there any adjustments pionts for the transmission. I have located the clutch adjustment but nothing changes.
By Rick Shropshire
I recently picked up a 2000 warrior 350 and it doesn’t have the air filter box so I was thinking about using a clamp on filter directly on the carb. Anyone know what I need to get or where I can find it? The one I ordered goes in the box and won’t fit directly on the carb.
By Hashlion
Ok. Here goes nothing. I have a Franken bike. It's half 99 half 01. Not really a big deal. So the lady I got the bikes from said it jumped time and won't start. One bike is complete and assembled the other is in pieces but there. I have had these for two years. I immediately did a tear down and rebuild. I went over everything. Well fast forward to now. I found that she only had 4 head bolts in it . That is why it jumped and also why she said the timing chain had to be real tight. I can get it timed well enough to start and idle rough. I've replaced bout everything. Compmetely new head and all head components. Upper cam gear, chain,cam,the whole thing. It won't line up matter what I do. The timing marks are just a wee bit off. It won't rev just backfires and dies. I've had the bikes for two years and can't get it. Great spark-built a bare bones harness myself. Great fuel-rebuilt the mikuni and bought an aftermarket, same outcome. I ha e half of mind to sell the two and but something else. PlEase help. The wife might kill me if I work on it anymore. Idk
By KennyB
Anyone know where I can find preferably new lower control arms with ball joints for a 1988 Honda trx300 Fourtrax 2x4?
or a place or person that can build me new ones
