By Rockbottom
By Rockbottom
Any body have a part number for replacing the safety interlock on the left brake so you can start the engine with the brake handle pulled and in gear
or how to bypass this function so you can start in gear
By Rockbottom
anybody have a electrical drawing
cant figure out problem
new starter relay, when i turn the key on all 3 leads to relay are hot red, blue, blue white. Is that correct. nothing happens ir clicks at the starter relay when i push the start button
on the relay closest to the cdi and nearest the brake light the relay vibrates as if it is opening and closing rapidly
the batter is new and good
if i short the B and M lugs on the starter relay the engines turns over but does not start and there is no spark
I ordered a new cdi but the one on the machine is only a few months old but a aftermarket
anybody have a electrical drawing or advice ir know what that relay symptom is and what activates it
By Coyote251
