I keep getting a grinding sound when it's put into gear. It happens both on the ground and jacked up.
I appreciate all your help, tips, and ideas.
Thank You.
Best way I can think to isolate it is to disconnect the transmission output shaft to the sub transmission. If it still makes noise its in the transmission. If not its in the sub transmission or the final drive.
    • By TimothyLindblom
      Hey all, I just picked up this Massimo UTV for $500. Got it home and replaced the starter solenoid which successfully got power to the starter. Starter spun but engine didn't turn over although the engine is not locked up. I thought it was a bad starter. Got a new starter put on today and it does the same thing. Pulled the clutch cover and saw the engine is trying to turn over but something is slipping and not letting it turn over. I figured it must be the gear on the engine that the starter turns. Where can I get that and can it be replaced without pulling the motor? And am I correct that that's the issue?
      Thanks!
      Short video attached below
    • By qcm413
      Hi,
      Thanks for a newbie on this site !
      i have grinding noise in my front differential. the front right wheel is turning and the left is try to turn but no movement and make sound like a gear broken. somebody have any idea ? not enough oil in diff ?
      thank
    • By Werewolf
      My Yamaha Big Bear shifts through all the gears good, goes into reverse smoothly, but when i go to get out of reverse it takes a lot of effort to get it back to first gear, and even then it does not go very smoothly, have to pull up on the pedal really hard, anyone else ever had this problem. Any ideas would be greatly appreciated.
    • By RiverRoad
      I need a wiring diagram pertaining  my polaris 1999 335 sportsman
