Guest VINCH
When i connect my battery the 30a fuse on the starter relay blows
I checked the starter cable and starter ALL GOOD
I did note however when the B/W small wire from ground terminal of battery is disconnected
And I connect the Large cables no fuse blown
This is on a 2000 Suzuki LTA500F Quadmaster 500
Bottom line every time I connect the battery cables I blow the 30a fuse thus no power to anything at all. Wiring all looks intact I exposed almost all of the wiring harness tracing the small B/W wire from the grounded side of the battery
could it be the CDI unit or rectifier
I did replace the starter relay that is fused 30a as the original relay was blown
Any thoughts are greatly appreciated
Guest VINCH
25 views and o replies come on guys and gals someone has to have something
Guest VINCH
Turned out the Red wired off the top of the ignition relay had a rub through in it. Oddly enough up by the key switch. Also has some debris at the contact points in the key ignition contacts. I also had to replace the ignition relay again. All is fixed and it runs like a champ again thanks for the help
    • By logray
