Had been sitting up for 6 months or more, changed oil, air filter, plug and gas. Cranks right up as long as you leave choke engauged, but once you disengage, goes dead. If I leave choke on and listen, sounds like a faint grinding noise in motor. Every once in awhile I will hear a thump. A friend said to run premium gas (about 3 tanks) and seafoam and it should work it out. Lol what do you think?
    • By canamKID
      20260711_150338.mp4
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
    • By kevinohio
    • By BillR94
      Thank you for your time
      Bill
    • By Jason39
