Similar Topics
By Cheetah
Hello ! Does anyone know why when I start my quad the idle go very fast ? The only thing I did is change the fuel line and the fuel filter.
By chadd7
I bought a used 2019 ds 70 a couple weeks ago for my son. If I had to guess it has under a 100 miles. It still has the nubs on the tires.
It starts right up on the first crank. After he rides for a couple minutes it will stall when he stops. If he doesn't stop it won't stall but as soon as he stops it shuts off. I can get it started but it take about 3 minutes of cranking the engine before it will fire back up. Then again after a couple minutes of riding it will stall as soon as he stops. Any recommendations?
By TSWIII
I let my ArticCat sit over the winter but before it was put in the garage it was running perfect. In taking it out this year it wouldn't start. I can start it with a charger and it will idle just fine. But it's doing something weird now. Either the display 1)won't display anything or 2) it will just display the analog speedometer but none of the digital stuff or 3) it will display all. So it was acting really sluggish when in HIGH gear and sounded like it was in low gear. So in driving it down the road and it being sluggish, I switched the ignition key to "Lights ON" and the ATV immediately picked up as though it really was in HIGH gear. Switching the ignition back to "ON" was like down shifting into LOW gear. When I came to a stop and switched from LIGHTS on to just ON the ATV completely died. After a 30 minute ride you would think it would start again but I had to jump it again to get it to start. Same issues with the ignition having to be pointed to Lights for it to run decently. Then just as I got back to home base the display showed VOLT. It acts like it's something in the ignition but not sure how that's related to the gears. I put a gas cleaner in the tank since it's been sitting but it really doesn't seem like a bad gas issue that I thought it was at first. I checked the IGN fuse but it seems fine, replaced it with the extra fuse but no joy. Anyone have any ideas?? Thanks in advanced for any help. It's much appreciated.
By timberwolf357
i added this video because its hard to explain what it's doing. i cant figure this problem out. i thought it was fuel. but its got good flow from the tank and i tried a different carb and got the same result. hiting the throttle doesnt change anything. it's driving me nuts. it has a new stator and coil.
video-1656360395.mp4 -
By 406offroad
I have a 2014 CForce 500 and the pull start is not cooperating. It seems as if it is not releasing the compression thus allowing me to spin the engine with the pull start. Any ideas?
Similar Tagged Content
- 10 replies
- 1,188 views
- 1 reply
- 1,942 views
- 1 reply
- 3,670 views
- 0 replies
- 1,923 views
- 1 reply
- 2,318 views
Gallery Images
