SuperATV Foreman Rear Disk Conversion
By quadcrazy
Best ATV for Older Riders
Polaris Sportsman 570 EPS
Best Reliable ATV for Seniors
Honda FourTrax Rancher EPS
Best Features
Best Premium Comfort ATV
Can-Am Outlander MAX
Standout Comfort Features
Best ATV for Easy Handling
Suzuki KingQuad 500AXi
Why Older Riders Like It
Yamaha Grizzly 700 EPS
Best Features
Arctic Cat Alterra 600 TRV
Key Advantages
Electric Power Steering (EPS)
Automatic Transmission
Lower Seat Height
Two-Up Models
Hand Warmers and Heated Grips
Adjustable Suspension
Buying Too Much Power
Ignoring EPS
Choosing Aggressive Tires
For most mature riders:
Final Thoughts
By Admin
By Olchap
Hi, I am new to this forum and I am happy to be here. I purchased a Yamaha 350 Big Bear without a title and I cannot find a Vin number to find out what year it is. I am hoping someone here can help me identify this atv. I checked on the main frame near the front A-arm left side found nothing. I checked up near the radiator and found nothing. Where else should I look? See image below.
By tcd
Ok recently got a "what i believe" is a 2003 rancher 4x4. I believe it is a 350te. Obviously a project. Wire harness was in bad shape.
Reconnecting wiring harness. Have one harness that does not match...... the end or front side of the harness has this harness. .... appears to be the one that connects to the dash./ LED indicators... The only wires (indicators) that I can find that does not have a match to the main harness connection. These 2 harnesses do not appear to go together . it appear the harness or dash cluster were changed and don't match. Dash/indicator light wire harness was cut off. Attaching pics of both connections. Is there a way to make this work or do I need to buy a new harness or cluster?
By Daniel1971
I have a 2009 Honda rancher that has fuel coming out of the injector but will not crank. I can spray gas in through the breather and it will run a few seconds. Any help appreciated
