misfire problem
rogtro
I have a 1990 klf 300 b3 bayou starts good an idles good some times runs good some times it misfires just off idle can shut off 5 min an restart may run fine may still misfire cleaned tank and carb also not charging bat are they related stater volts 20.3 ac three yellow wires at high idle have new reg coming can this be misfire problem or something else update got new regulater fixed charging problem but atv still misfires at times any one have any ideas what to look at next thanks roger
Edited by rogtro
update
  • 3 years later...
    • By N00bie
    • By hardcastle
    • By ResQ91
      Hi Guys!
      Or ??
      Dave
    • By Louznmemind
      Howdy y'all, I'm trying to fix a neighbors 2015 Brute Force 300. Came in with hard to start and won't idle except on choke issue. I pulled the carb and found the pilot jet as well as the emulsion tube partially clogged. Cleaned up everything, put it back together, still having issues...  It will start right up on choke and will also start off choke if you give it just a touch of throttle but it absolutely will not idle unless it's choked just a touch. Also, excuse my ignorance but I'm assuming the "dial" thingy attached to the carb that turns in and out is for setting idle??
    • By Its-always-something
