Thanks in advance for any advice given!
My 4 year old has been driving his lt50 with his hand on the brake & burnt out them out.....can anyone point me in the right direction to get a shop manual for it or even just advise how to get into the drum to replace the shoes?
Cheers!!
in one of the forums, they have a list of many manuals, might be there,?? also, take a pict and we can see the damage, maybe learn from it ?, I just did my rear brakes, and it was pretty easy, currently getting the drum re-surface at a machine shop.. might want to investigate that as well..it was pretty cheap..
Thanks for the reply, the only manual I can find on the forum that's even close is for the lt 80 but that has hydraulic brakes, my boy's lt50 has a single drum in the middle of the rear axle with what I presume will be cable operated shoes. Can't post a pic yet as I haven't stripped the brakes yet.... Is it just a case of stripping down the back axle to get into the drum? Or am I missing something simpler?
It's a 91 mate, lt50 quad runner. I went for it this afternoon & pulled the wheel & shaft cover, such a simple brake setup, much simpler than I was expecting... Drum was full of mud, no wonder they weren't working properly! Also fabricated a set of foot guards to stop his wee feet slipping under the wheels when they come off the pegs.
Would still appreciate a manual if somebody's got one incase I need to do more in depth work!
Cheers
Are you sure its a LT50 or a 91? The last LT50 made according to Bike Bandit parts data base was 1987. Went to mygreenmanuals.com and nothing there either. Though Im not sure about UK models. Can you post the vin num?
Sounds like you are on the right track with the problem though. Simple cable drum brake setup.
You were missing the last 3 digits so i just used 111. Just serial number location:
VIN check & analyze
Entered VIN LM4AA123321117111
Corrected VIN LM4AA123321117111
WMI LM4 Make Suzuki
VDS AA123321 VIS Identifier not applicable
Year 2 Year Info 2002
Check Digit Not applicable Matching Data 54.4% accuracy
Manufacturer
Manufacturer Tai Ling Engineering & Development Co
Addres Chung Lung Building
#261 Sung Chiang Road
Region Asia
Country China
Note Manufacturer builds more than 500 vehicles per year
Vehicle Details
Make Suzuki Body Style All Terrain
Model LT50 Vehicle Class All Terrain Vehicle
Versions K2 Vehicle Type Motorcycle
Series No Data Model Year/s 2002
Doors No Data Build Year No Data
Seats No Data Plant Atvs - Taiwan (China)
Technical Information
Engine Configuration No Data Fuel Type Petrol
Engine Type No Data Emission Standard No Data
Engine Version No Data Displacement SI 49 cc3
Valve operation No Data Displacement CID 3 Cubic Inches
Valves 2 Displacement Nominal No Data
Cylinders 1 Driveline Rear Wheel Drive
Engine HorsePower No Data Steering No Data
Engine KiloWatts No Data Transmission No Data
Charger (turbo/super/diesel) No Data Gears No Data
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
